Occasional Contributor I
Disappearing and reappearing SSID
Besides CCI or APs going offline, what would cause ssid to disappear one minute and reappear another minute? Thanks
Re: Disappearing and reappearing SSID
If the AP keeps bootstrapping and the GRE Tunnel keeps dropping that could cause that the SSIDs or SSID keeps disappearing, each builds a GRE tunnel per SSID
Please run the following commands to see if that is the case:
show ap debug counters | include <apname>
show ap debug system-status ap-name <apname>
show log system 100
When you see that happening also run :
show ap bss-table ap-name <apname>
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Also if you are on the 'fringe' of coverage the SSID may appear to come-and-go.   What RSSI/signal level do you have when the SSID is present ?
Thanks Victor
rssi is -69, pretty strong
Cheif, That could happen if:
- You are in an area with a great deal of multipath, or outdoors
- You have a client that is known to exhibit that behavior (Android, I am looking at you)
Please measure with two different client platforms at the same time.
Colin Joseph
Aruba Customer Engineering
Frequent Contributor II
First please confirm with the command :show ap bss-table ap-name <name of the AP> that the uptime of the tunnel was reseted.
If that doesn't happen then I would suggest to indeed confirm what cjoseph suggested - to validate with more than 1 device (maybe different OS's) that the SSID is dissapearing.
Enable debug on the AP's in question in order to see more information in the logs maybe even debug on some of the clients in that area.
If you found my post helpful, please give kudos!
Super Contributor I
How far is the client from the APs, use more than 1 clients to try (use tools like INSSIDER to see the signal strength etc) and use command in Aruba such as show AP bss-table to further verified.
Normal Guy
