Disassoc with reason code 255 from Aruba
I am seeing Disassoc with reason code 255 from Aruba AP after client sends disassoc with reason code 1(unspecified reason).
I read it in other thread that controller reporting that the client sent a deauth to the AP and did not give a reason.
If the above information is true then, I would like to know how it helps? Is there a reason behind this kind of information.
Re: Disassoc with reason code 255 from Aruba
It is fairly generic and you are right, it is not helpful.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
