AAS
Disconnect client if client does not obtain valid IP - Controllers
I worked with some controllers that had the "Force DHCP" option whose purpose was disconnect client if client does not obtain valid IP address, for example if a user manually change your IP and put the gateway IP,  the system detects and disconnects the user.
I would like to know where this option is in the Aruba controllers.
Thank you
Re: Disconnect client if client does not obtain valid IP - Controllers
"Enforce DHCP".  http://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/aaa_profile.htm?Highlight=enforce dhcp
Colin Joseph
Aruba Customer Engineering
AAS
Thank you Colin Joseph.
