Occasional Contributor I
Disconnect clients after a connection time.
Hello!,
I have several Aruba Aps model 215, without controller, and I would like to propagate an open ssid that provides access to the internet, but that users can be connected 1 hour, and after that time connected, automatically disconnect them and disable them to reconnect for at least 10 minutes.
This SSid is for the visits, but I would not want the users of the building to spend all day connected consuming the bandwidth of this connection.
Is there any way to achieve this?
Thanks in advance.
Re: Disconnect clients after a connection time.
Here's some details about how to configure the guest SSID. Youtube Video.
To kick people off the guest SSID and back to the captive portal you can set the "Reauth inteval" to 1 hour. I don't believe you can stop people from re-authenticating for 10 minutes though unless you have something like ClearPass.
Cheers
James
Cheers
James
Thanks!
