Regular Contributor I
Display end of connection
In Airwave under Clients, is it possible to display the date and time of the end of the connection (like the association time) instead of the Duration ?
Dimitri
Moderator
Re: Display end of connection
At this time, AirWave shows the association time and duration.  This is a good feature request to submit into the Ideas Portal on the support site.
Rob Gin
Senior QA Engineer - Network Services
Aruba Networks, a Hewlett Packard Enterprise Company
Ok thanks I will do this.
Regards
Dimitri
