Does ARM works for APs in different Ap-Groups?
I have a Requirement to have different VLANs for each building floor, I'll be using the same SSID, I created an AP-Group for each floor in order to change the VLAN and maintain the SSID. Does ARM (if keeping the defaul profile) runs over all floor APs?, or it will be running only for APs in each AP-group?
Re: Does ARM works for APs in different Ap-Groups?
Yes, it's by controller where the AP terminates.
Tim Cappalli | Aruba Security
