Frequent Contributor II
Does Ap68 work with OS 6.3?
Re: Does Ap68 work with OS 6.3?
Yes
Tim Cappalli | Aruba Security
Aruba
You can also refer to this table to confirm the last support release of any of our APs.
http://www.arubanetworks.com/support-services/end-of-life-products/#AccessPoints
Best regards,
Madani
