Does Aruba 3600 & 6000 M3 controller support Radius Management login
Hi there,
We have Aruba 3600 master controller and 6000 M3 local controller setup and currently we are using local account. (root) to login and do configuration. Since root is a shared account, we'd like to enable the controler with radius or AD authentciation so it is easy to log the activity have been done on the system.
Kindly share me the document or steps if it is support
Many thanks in advanced!
Re: Does Aruba 3600 & 6000 M3 controller support Radius Management login
http://community.arubanetworks.com/aruba/attachments/aruba/115/80/1/Management+Authentication+using+Windows+IAS+as+a+Radius+Server.doc
