Contributor II
Does Aruba 650 controller supports AOS 6.4?
Re: Does Aruba 650 controller supports AOS 6.4?
Yes but:
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Contributor II
Great Thanks...
hence 205AP "access point" works on 650 controller with 6.4 OS?
The minimum OS version to bring up AP-205 is 6.4.1.0.
If your 650 is running on 6.4.1.0 or higher, AP-205 should work fine.
http://www.arubanetworks.com/assets/ds/DS_AP200Series.pdf
