Frequent Contributor II
Does Aruba Instant AP need license like PEF-NG and so on?
When deploying IAP do we need licenses ?
Re: Does Aruba Instant AP need license like PEF-NG and so on?
No.
The only licenses for Instant are:
Aruba Central - cloud management licensed by AP
AirWave - on-prem management licensed by AP
Controller PEF-V - licensed by controller for advanced IAP-VPN deployments (RBAC)
None of these are required for IAP functionality.
Tim Cappalli | Aruba Security
I can't find PEV-V for Instant ! kindly advice
It's not a required license. You only need this for the IAP-VPN architecture if you are doing advanced role-based access. (It is a controller license)
So you mean I can use RBAC with instant without any license?
Super Contributor I
Yes. RBAC is built into the instant platform and can be used without anything additional. The PEF-V license is for controllers and is only needed in certain scenarios to create a tunnel between an IAP cluster and a controller.
ACDX #419 | ACMP |
Yes, you can.
Thanks Guys I really got it
