Contributor II
Does Aruba have a SNR matrix?
Hi guys,
Like this:
Modulation    SNR
BPSK              15
QPSK              19
16QAM            25
64QAM
256QAM
The number I'm given is not the right figure, I just want to illustrate it.
Re: Does Aruba have a SNR matrix?
The receive sensitivity is probably what you are after I guess.  This can vary between different models of APs.  The information is found in the data sheets for the APs.
ACCP, ACCX #817, ACMP, ACMX #294
Contributor II
Hi Michael,
I'm sorry, I only found the receiver Power, but couldn't find the SNR value.
http://www.arubanetworks.com/pdf/products/DS_AP210Series.pdf
And Do you know  the Minimum SNR for 802.11ac?
Page 4 has the info.
This link is also an excellent reference point to refer to http://mcsindex.com/
