Frequent Contributor II
Does Aruba have access points with more than 2 ports rather than AP103H?
I need AP with 2 ports ethernet ?
Re: Does Aruba have access points with more than 2 ports rather than AP103H?
The 103H is your only option.
Tim Cappalli | Aruba Security
Can I deploy it outdoors like on small shop?
You could put it in an enclosure, but it is not designed for outdoor coverage.
Super Contributor I
I assume this is for downlinks to other devices? If you can tolerate a single VLAN and 100Mbps, maybe check with your rep as to whether a 225 using .11at power can handle one of those little 5-port 10/100 USB-powered switches.  Not that any of that is designed for outdoors either.
Another access ponits you can use
RAP155
It has 4 ethernet ports, and it has option for 2 of them being poe..
That AP is indoor so dont use it outdoor...
Cheers
Carlos
Alternetworks Corp
