Nah
Occasional Contributor I
Does ArubaOS8 supports DHCP redundancy?
Hi everybody,
I have received request to deply DHCP server on Master redundancy controllers. Two controller syncs profiles but DHCP server configuration.
By the way, it's Aruba OS 6.
I've look throught the topics to find out for does aruba controller redundancies DHCP lease and client list.
I found out below link that shows it does not supports which was in about 3 years ago.
https://community.arubanetworks.com/t5/Wireless-Access/Master-Redundancy-and-DHCP-Server/td-p/224849
Also, I couldn't see any commnad line related to DHCP redundancy from "ArubaOS 8.0.0.0 CLI Reference Guide" as well.
Is it still not supports DHCP redundancy feature even this days?
Has anyone seen this feature from Aruba OS8?
Please tell me if anyone had similar experience.
Thank you in advance.
Frequent Contributor I
Re: Does ArubaOS8 supports DHCP redundancy?
You could just double the size of your scope and split it between the two controllers and exclude. For example, make your scope a /23 and put each /24 on a controller and exclude the other range on each.
#AirheadsMobile
#AirheadsMobile
No DHCP redundancy
Thank you
Victor Fabian
Lead Mobility Architect @WEI
