Does RAP firmware update automatically when controller does?
I am getting ready to update our 3200 series controllers from 6.1.3.10 to 6.1.3.11. Does the RAP firmware get updated as well next time they connect?
MVP
Re: Does RAP firmware update automatically when controller does?
Yes,It will upgrade automatically and will reboot.
(using TFTP process while rebooting on, port 69udp)
Thanks, I wasnt sure if they upgraded for each release or just certain iterations
MVP
Yes,it's must be identical AOS  - if not your RAP/AP will not work
