fe
Occasional Contributor I
Does anyone currently using Clearpass with Enterasys Switches?
Does anyone currently using Clearpass with Enterasys Switches? If so.
1. are you cuttently doing a redirect to the captive portal to ClearPass on a wired port doing MacAuth? If yes, How?
2. are currently doing 802.1x with windows logon on a Mac running  10.7 and up? If so, what did you use to push out the configs? was it a Casper server? if yes, any docs on how to set it up.
3. I'm also expiriencing a very long delay when doing a .1x auth on the Mac. any idia on how to fix that.
Any input will be greatly appriated.
Trusted Contributor I
Re: Does anyone currently using Clearpass with Enterasys Switches?
sorry not experience, but i would advise to post at: Technology > AAA, NAC, Guest Access & BYOD.
also try the Enterasys Switches forum.
