Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
  • 1.  Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted Apr 09, 2015 03:29 PM
    I'm working w/ RANCID 2.3.2, and have hacked up a clogin script to backup the Aruba 7005 configs. However, it has issues with the prompt (likely the "(" and ")". I'm not good with expect, so I'm not sure what I'm not getting right, so I figured I'd ask if anyone has an example script for arubarancid or arubalogin, much like the Cisco clogin that comes with RANCID.
    I realize there have been other ways of doing this, but I'm a fan of consistency with how we back up Dell and Cisco gear, and want to get RANCID working. A good answer here would answer many others' questions as well.
    Thanks!
  • 2.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted Apr 09, 2015 07:34 PM
    Here are the two relevant files I'm using.  You'll also have to rename the files to remove the .txt extension, and also manually modify your rancid-fe script if you haven't already.  Enjoy!
    Attachment(s)
    txt
    arosrancid.txt   16 KB 1 version
    txt
    aroslogin.txt   21 KB 1 version
  • 3.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted Apr 10, 2015 11:44 AM
    Thanks! I must be having a different type of issue. It seems the aroslogin script (or rather, RANCID) doesn't detect that it has successfully logged into the Controller. I see my Login prompt, "(Aruba-wlc-Master) >", but then eventually I see, "Error: TIMEOUT reached". So, it never completes the enable process. Should it continue?
    I'm guessing this isn't because of the "()" in the prompt, as this seems to be taken care of.
  • 4.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted Apr 15, 2015 12:49 PM
    This was posted to the RANCID discussion list a few weeks back...
    https://github.com/miken32/rancid-aruba/
  • 5.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted Apr 15, 2015 12:58 PM
    Unfortunately, the clogin script doesn't work in my case. The script doesn't detect the correct prompt, so it thinks it hasn't successfully logged in. I'm learning expect so I can somehow tailor the script to work for my install.
    [rancid@server~]$ arubalogin bnahq-wlc01
    bnahq-wlc01
    spawn ssh -c 3des -x -l rancid bnahq-wlc01
    parent: waiting for sync byte
    parent: telling child to go ahead
    parent: now unsynchronized from child
    spawn: returns {30645}
    expect: does "" (spawn_id exp6) match regular expression "(Connection refused|Secure connection [^
    \r]+ refused)"? no
    "(Connection closed by|Connection to [^
    \r]+ closed)"? no
    expect: does "" (spawn_id exp6) match glob pattern "unknown host\r"? no
    expect: does "" (spawn_id exp6) match glob pattern "Host is unreachable"? no
    "No address associated with name"? no
    "(Host key not found |The authenticity of host .* be established).*(yes/no)?"? no
    "HOST IDENTIFICATION HAS CHANGED.* (yes/no)?"? no
    "Offending key for .* (yes/no)?"? no
    "(denied|Sorry)"? no
    "Login failed"? no
    "% (Bad passwords|Authentication failed)"? no
    "Press any key to continue."? no
    "Enter Selection: "? no
    "@[^\r
    ]+ ([Pp]assword|passwd):"? no
    "([Pp]assword|passwd):"? no
    ">"? no
    "Login invalid"? no
    rancid@bnahq-wlc01's password:
    expect: does "rancid@bnahq-wlc01's password: " (spawn_id exp6) match regular expression "(Connection refused|Secure connection [^
    \r]+ refused)"? no
    \r]+ closed)"? no
    expect: does "rancid@bnahq-wlc01's password: " (spawn_id exp6) match glob pattern "unknown host\r"? no
    expect: does "rancid@bnahq-wlc01's password: " (spawn_id exp6) match glob pattern "Host is unreachable"? no
    "Login failed"? no
    "@[^\r
    ]+ ([Pp]assword|passwd):"? yes
    expect: set expect_out(0,string) "@bnahq-wlc01's password:"
    expect: set expect_out(1,string) "password"
    expect: set expect_out(spawn_id) "exp6"
    expect: set expect_out(buffer) "rancid@bnahq-wlc01's password:"
    send: sending "(password-removed)" to { exp6 }
    expect: continuing expect
    expect: does " " (spawn_id exp6) match regular expression "(Connection refused|Secure connection [^
    \r]+ refused)"? no
    \r]+ closed)"? no
    expect: does " " (spawn_id exp6) match glob pattern "unknown host\r"? no
    expect: does " " (spawn_id exp6) match glob pattern "Host is unreachable"? no
    "Login failed"? no
    "@[^\r
    ">"? no
    "Login invalid"? no
    expect: does " \r
    \r]+ refused)"? no
    \r]+ closed)"? no
    expect: does " \r
    expect: does " \r
    "Login failed"? no
    "@[^\r
    ">"? no
    "Login invalid"? no
    Last login: Tue Apr 14 14:13:19 2015 from 10.0.23.165
    expect: does " \r
    Last login: Tue Apr 14 14:13:19 2015 from 10.0.23.165\r\r
    \r]+ refused)"? no
    \r]+ closed)"? no
    expect: does " \r
    expect: does " \r
    "Login failed"? no
    "@[^\r
    ">"? no
    "Login invalid"? no
    (bnahq-wlc01-Master) >
    expect: does " \r
    \r
    \r
    (bnahq-wlc01-Master) >" (spawn_id exp6) match regular expression "(Connection refused|Secure connection [^
    \r]+ refused)"? no
    \r]+ closed)"? no
    expect: does " \r
    \r
    \r
    (bnahq-wlc01-Master) >" (spawn_id exp6) match glob pattern "unknown host\r"? no
    expect: does " \r
    \r
    \r
    (bnahq-wlc01-Master) >" (spawn_id exp6) match glob pattern "Host is unreachable"? no
    "Login failed"? no
    "@[^\r
    ">"? yes  ( I changed $prompt to simply be ">" so that the prompt will match. )
    expect: set expect_out(0,string) ">"
    expect: set expect_out(buffer) " \r
    \r
    \r
    send: sending "\r" to { exp6 }
    expect: does "" (spawn_id exp6) match regular expression "[\r
    ]+"? no
    "^(.+:)1 #"? no
    "^.+#"? no
    "^.+> \(enable\)"? no
    expect: does "\r
    (bnahq-wlc01-Master) >" (spawn_id exp6) match regular expression "[\r
    ]+"? yes
    expect: set expect_out(0,string) "\r
    expect: set expect_out(buffer) "\r
    expect: does "(bnahq-wlc01-Master) >" (spawn_id exp6) match regular expression "[\r
    ]+"? no
    "^(.+:)1 #"? no
    "^.+#"? no
    expect: timed out
    write() failed to write anything - will sleep(1) and retry...
    [rancid@server~]$
  • 6.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted Apr 15, 2015 06:26 PM
    Ironically, the answer was to add to the .cloginrc file, add autoenable bnahq-wlc*           0
  • 7.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted May 13, 2015 03:31 PM
    Ok, so here's an update. (And I'm noting that this editor doesn't typically honor fonts or font sizes when used by some browsers.)
    Some users will use the LDAP configuration for assigning users to specific profiles. When you do this, your config will include something like:
    admin-passwd (changing key)
    When you see this in the config that is backed up by R.A.N.C.I.D. (RANCID), it will change, causing a subversion update to happen. This was a problem for me, but I'll detail my fix.
    SO, if you want to use RANCID to back up your Aruba 7005 (possibly others), do the following:
    ****** Step 1 ****** (Assuming you already have RANCID installed and working on Cisco or other devices)
    Create an arubarancid file (vi or touch, etc.):
    Copy the entire text below into a new file called, "arubarancid" which should reside in the same
    directory as your rancid-run and rancid-fe executables
    ##### Copy the following to END OF FILE #####
    #! /usr/bin/perl
    ## $Id: rancid.in,v 1.255 2009/04/20 19:56:27 heas Exp $
    ## rancid 2.3.2
    ## Copyright (c) 1997-2009 by Terrapin Communications, Inc.
    ## All rights reserved.
    ## Edited by Brian Murphree on 5-13-2015 for Aruba 7005 Controllers
    ## This code is derived from software contributed to and maintained by
    ## Terrapin Communications, Inc. by Henry Kilmer, John Heasley, Andrew Partan,
    ## Pete Whiting, Austin Schutz, and Andrew Fort.
    ## Redistribution and use in source and binary forms, with or without
    ## modification, are permitted provided that the following conditions
    ## are met:
    ## 1. Redistributions of source code must retain the above copyright
    ## notice, this list of conditions and the following disclaimer.
    ## 2. Redistributions in binary form must reproduce the above copyright
    ## notice, this list of conditions and the following disclaimer in the
    ## documentation and/or other materials provided with the distribution.
    ## 3. All advertising materials mentioning features or use of this software
    ## must display the following acknowledgement:
    ## This product includes software developed by Terrapin Communications,
    ## Inc. and its contributors for RANCID.
    ## 4. Neither the name of Terrapin Communications, Inc. nor the names of its
    ## contributors may be used to endorse or promote products derived from
    ## this software without specific prior written permission.
    ## 5. It is requested that non-binding fixes and modifications be contributed
    ## back to Terrapin Communications, Inc.
    ## THIS SOFTWARE IS PROVIDED BY Terrapin Communications, INC. AND CONTRIBUTORS
    ## ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
    ## TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
    ## PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COMPANY OR CONTRIBUTORS
    ## BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
    ## CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
    ## SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
    ## INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
    ## CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
    ## ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
    ## POSSIBILITY OF SUCH DAMAGE.
    # RANCID - Really Awesome New Cisco confIg Differ
    # usage: rancid [-dV] [-l] [-f filename | hostname]
    use Getopt::Std;
    getopts('dflV');
    if ($opt_V) {
    print "rancid 2.3.2
    exit(0);
    $log = $opt_l;
    $debug = $opt_d;
    $file = $opt_f;
    $host = $ARGV[0];
    $clean_run = 0;
    $found_end = 0;
    $found_version = 0;
    $found_env = 0;
    $found_diag = 0;
    $timeo = 90; # clogin timeout in seconds
    my(@commandtable, %commands, @commands);# command lists
    my($aclsort) = ("ipsort"); # ACL sorting mode
    my($config_register); # configuration register value
    my($filter_commstr); # SNMP community string filtering
    my($filter_pwds); # password filtering mode
    # This routine is used to print out the router configuration
    sub ProcessHistory {
    my($new_hist_tag,$new_command,$command_string,@string) = (@_);
    if ((($new_hist_tag ne $hist_tag) || ($new_command ne $command))
    && defined %history) {
    print eval "$command \%history";
    undef %history;
    if (($new_hist_tag) && ($new_command) && ($command_string)) {
    if ($history{$command_string}) {
    $history{$command_string} = "$history{$command_string}@string";
    } else {
    $history{$command_string} = "@string";
    } elsif (($new_hist_tag) && ($new_command)) {
    $history{++$#history} = "@string";
    } else {
    print "@string";
    $hist_tag = $new_hist_tag;
    $command = $new_command;
    1;
    sub numerically { $a <=> $b; }
    # This is a sort routine that will sort numerically on the
    # keys of a hash as if it were a normal array.
    sub keynsort {
    local(%lines) = @_;
    local($i) = 0;
    local(@sorted_lines);
    foreach $key (sort numerically keys(%lines)) {
    $sorted_lines[$i] = $lines{$key};
    $i++;
    @sorted_lines;
    # This is a sort routine that will sort on the
    sub keysort {
    local(%lines) = @_;
    local($i) = 0;
    foreach $key (sort keys(%lines)) {
    $i++;
    @sorted_lines;
    # values of a hash as if it were a normal array.
    sub valsort{
    local(%lines) = @_;
    local($i) = 0;
    foreach $key (sort values %lines) {
    $sorted_lines[$i] = $key;
    $i++;
    @sorted_lines;
    # This is a numerical sort routine (ascending).
    sub numsort {
    local(%lines) = @_;
    local($i) = 0;
    foreach $num (sort {$a <=> $b} keys %lines) {
    $sorted_lines[$i] = $lines{$num};
    $i++;
    @sorted_lines;
    # ip address when the ip address is anywhere in
    # the strings.
    sub ipsort {
    local(%lines) = @_;
    local($i) = 0;
    foreach $addr (sort sortbyipaddr keys %lines) {
    $sorted_lines[$i] = $lines{$addr};
    $i++;
    @sorted_lines;
    # These two routines will sort based upon IP addresses
    sub ipaddrval {
    my(@a) = ($_[0] =~ m#^(\d+)\.(\d+)\.(\d+)\.(\d+)$#);
    $a[3] + 256 * ($a[2] + 256 * ($a[1] +256 * $a[0]));
    sub sortbyipaddr {
    &ipaddrval($a) <=> &ipaddrval($b);
    # This routine processes a "write term"
    sub WriteTerm {
    print STDERR " In WriteTerm: $_" if ($debug);
    my($lineauto,$comment,$linecnt) = (0,0,0);
    while (<INPUT>) {
    tr/\015//d;
    last if (/^$prompt/);
    return(1) if /Line has invalid autocommand /;
    return(1) if (/(Invalid input detected|Type help or )/i);
    return(1) if /\%Error: No such file or directory/;
    return(0) if ($found_end); # Only do this routine once
    return(-1) if (/command authorization failed/i);
    # the pager can not be disabled per-session on the PIX
    if (/^(<-+ More -+>)/) {
    my($len) = length($1);
    s/^$1\s{$len}//;
    if (!$linecnt && defined($config_register)) {
    ProcessHistory("","","", "!
    config-register $config_register
    /Non-Volatile memory is in use/ && return(-1); # NvRAM is locked
    $linecnt++;
    $lineauto = 0 if (/^[^ ]/);
    # skip the crap
    if (/^(##+|(building|current) configuration)|^System Time:|^Switch uptime is|^Internal Temperature/i) {
    while (<INPUT>) {
    next if (/^Current configuration\s*:/i);
    next if (/^:/);
    next if (/^([%!].*|\s*)$/);
    next if (/^System Time:/);
    next if (/^Switch uptime is/);
    next if (/^Internal Temperature/);
    last;
    tr/\015//d;
    # skip consecutive comment lines to avoid oscillating extra comment
    # line on some access servers. grrr.
    if (/^!/) {
    next if ($comment);
    ProcessHistory("","","",$_);
    $comment++;
    next;
    $comment = 0;
    # filter out any RCS/CVS tags to avoid confusing local CVS storage
    s/\$(Revision|Id):/ $1:/;
    # order access-lists
    /^access-list\s+(\d\d?)\s+(\S+)\s+(\S+)/ &&
    ProcessHistory("ACL $1 $2","$aclsort","$3","$_") && next;
    # order extended access-lists
    /^access-list\s+(\d\d\d)\s+(\S+)\s+ip\s+host\s+(\S+)/ &&
    ProcessHistory("EACL $1 $2","$aclsort","$3","$_") && next;
    /^access-list\s+(\d\d\d)\s+(\S+)\s+ip\s+(\d\S+)/ &&
    /^access-list\s+(\d\d\d)\s+(\S+)\s+ip\s+any/ &&
    ProcessHistory("EACL $1 $2","$aclsort","0.0.0.0","$_") && next;
    # order arp lists
    /^arp\s+(\d+\.\d+\.\d+\.\d+)\s+/ &&
    ProcessHistory("ARP","$aclsort","$1","$_") && next;
    /^ip prefix-list\s+(\S+)\s+seq\s+(\d+)\s+(permit|deny)\s+(\d\S+)(\/.*)$/ &&
    ProcessHistory("PACL $1 $3","$aclsort","$4","ip prefix-list $1 $3 $4$5
    && next;
    # order logging statements
    /^logging (\d+\.\d+\.\d+\.\d+)/ &&
    ProcessHistory("LOGGING","ipsort","$1","$_") && next;
    # order/prune snmp-server host statements
    # we only prune lines of the form
    # snmp-server host a.b.c.d <community>
    if (/^snmp-server host (\d+\.\d+\.\d+\.\d+) /) {
    if ($filter_commstr) {
    my($ip) = $1;
    my($line) = "snmp-server host $ip";
    my(@tokens) = split(' ', $');
    my($token);
    while ($token = shift(@tokens)) {
    if ($token eq 'version') {
    $line .= " " . join(' ', ($token, shift(@tokens)));
    if ($token eq '3') {
    } elsif ($token eq 'vrf') {
    } elsif ($token =~ /^(informs?|traps?|(no)?auth)$/) {
    $line .= " " . $token;
    } else {
    $line = "!$line " . join(' ', ("<removed>",
    join(' ',@tokens)));
    last;
    ProcessHistory("SNMPSERVERHOST","ipsort","$ip","$line
    } else {
    ProcessHistory("SNMPSERVERHOST","ipsort","$1","$_");
    next;
    if (/^(snmp-server community) (\S+)/) {
    ProcessHistory("SNMPSERVERCOMM","keysort","$_",
    "!$1 <removed>$'") && next;
    } else {
    ProcessHistory("SNMPSERVERCOMM","keysort","$_","$_") && next;
    # filter out LDAP admin-passwd keys
    if (/^(.* admin-passwd).*/) {
    ProcessHistory("ADMINPASSWD","keysort","$_",
    # filter out WPA and ipsec keys
    if (/^(.* wpa-hexkey).*/) {
    ProcessHistory("WPAIPSEC","keysort","$_",
    if (/^(.*localip .* ipsec).*/) {
    if (/^(.* key).*/) {
    if (/^(.* wpa-passphrase).*/) {
    if (/^(.* peer-ip-address .* ipsec).*/) {
    # order alias statements
    /^netdestination / && ProcessHistory("ALIAS","keysort","$_","$_") && next;
    # order ntp servers
    if (/^ntp server (\d+)\.(\d+)\.(\d+)\.(\d+)/) {
    $sortkey = sprintf("$1 %03d%03d%03d%03d",$2,$3,$4,$5);
    ProcessHistory("NTP","keysort",$sortkey,"$_");
    next;
    # catch anything that wasnt matched above.
    ProcessHistory("","","","$_");
    # end of config. the ": " game is for the PIX
    if (/^(: +)?end$/) {
    $found_end = 1;
    return(0);
    return(0);
    # dummy function
    sub DoNothing {print STDOUT;}
    # Main
    @commandtable = (
    {'no paging' => 'WriteTerm'},
    # {'show switchinfo' => 'WriteTerm'},
    # {'show roleinfo' => 'WriteTerm'},
    # {'show image version' => 'WriteTerm'},
    # {'show inventory' => 'WriteTerm'},
    # {'show country' => 'WriteTerm'},
    # {'show slots' => 'WriteTerm'},
    # {'show keys all' => 'WriteTerm'},
    # {'show license verbose' => 'WriteTerm'},
    # {'show ap license-usage' => 'WriteTerm'},
    # {'show datapath vlan table' => 'WriteTerm'},
    # {'show database synchronize' => 'WriteTerm'},
    # {'show master-redundancy' => 'WriteTerm'},
    # {'show switches' => 'WriteTerm'},
    # {'show ap database inactive' => 'WriteTerm'},
    # {'show ap database unprovisioned' => 'WriteTerm'},
    {'show run' => 'WriteTerm'},
    # Use an array to preserve the order of the commands and a hash for mapping
    # commands to the subroutine and track commands that have been completed.
    @commands = map(keys(%$_), @commandtable);
    %commands = map(%$_, @commandtable);
    $cisco_cmds = join(";",@commands);
    $cmds_regexp = join("|",@commands);
    if (length($host) == 0) {
    if ($file) {
    print(STDERR "Too few arguments: file name required
    exit(1);
    } else {
    print(STDERR "Too few arguments: host name required
    exit(1);
    open(OUTPUT,">$host.new") || die "Can't open $host.new for writing: $!
    select(OUTPUT);
    # make OUTPUT unbuffered if debugging
    if ($debug) { $| = 1; }
    if ($file) {
    print STDERR "opening file $host
    " if ($debug);
    print STDOUT "opening file $host
    " if ($log);
    open(INPUT,"<$host") || die "open failed for $host: $!
    } else {
    print STDERR "executing clogin -t $timeo -c\"$cisco_cmds\" $host
    " if ($debug);
    print STDOUT "executing clogin -t $timeo -c\"$cisco_cmds\" $host
    " if ($log);
    if (defined($ENV{NOPIPE})) {
    system "clogin -t $timeo -c \"$cisco_cmds\" $host </dev/null > $host.raw 2>&1" || die "clogin failed for $host: $!
    open(INPUT, "< $host.raw") || die "clogin failed for $host: $!
    } else {
    open(INPUT,"clogin -t $timeo -c \"$cisco_cmds\" $host </dev/null |") || die "clogin failed for $host: $!
    # determine ACL sorting mode
    if ($ENV{"ACLSORT"} =~ /no/i) {
    $aclsort = "";
    # determine community string filtering mode
    if (defined($ENV{"NOCOMMSTR"}) &&
    ($ENV{"NOCOMMSTR"} =~ /yes/i || $ENV{"NOCOMMSTR"} =~ /^$/)) {
    $filter_commstr = 1;
    } else {
    $filter_commstr = 0;
    # determine password filtering mode
    if ($ENV{"FILTER_PWDS"} =~ /no/i) {
    $filter_pwds = 0;
    } elsif ($ENV{"FILTER_PWDS"} =~ /all/i) {
    $filter_pwds = 2;
    } else {
    $filter_pwds = 1;
    ProcessHistory("","","","!RANCID-CONTENT-TYPE: aruba
    ProcessHistory("COMMENTS","keysort","B0","!
    ProcessHistory("COMMENTS","keysort","D0","!
    ProcessHistory("COMMENTS","keysort","F0","!
    ProcessHistory("COMMENTS","keysort","G0","!
    TOP: while(<INPUT>) {
    tr/\015//d;
    if (/[>#]\s?exit$/) {
    $clean_run = 1;
    last;
    if (/^Error:/) {
    print STDOUT ("$host clogin error: $_");
    print STDERR ("$host clogin error: $_") if ($debug);
    $clean_run = 0;
    last;
    while (/#\s*($cmds_regexp)\s*$/) {
    $cmd = $1;
    if (!defined($prompt)) {
    $prompt = ($_ =~ /^([^#]+#)/)[0];
    $prompt =~ s/([][}{)(\\])/\\$1/g;
    print STDERR ("PROMPT MATCH: $prompt
    ") if ($debug);
    print STDERR ("HIT COMMAND:$_") if ($debug);
    if (! defined($commands{$cmd})) {
    print STDERR "$host: found unexpected command - \"$cmd\"
    $clean_run = 0;
    last TOP;
    $rval = &{$commands{$cmd}};
    delete($commands{$cmd});
    if ($rval == -1) {
    $clean_run = 0;
    last TOP;
    print STDOUT "Done $logincmd: $_
    " if ($log);
    # Flush History
    ProcessHistory("","","","");
    # Cleanup
    close(INPUT);
    close(OUTPUT);
    unlink("$host.raw") if (! $debug);
    # check for completeness
    if (scalar(%commands) || !$clean_run || !$found_end) {
    if (scalar(%commands)) {
    printf(STDOUT "$host: missed cmd(s): %s
    ", join(',', keys(%commands)));
    printf(STDERR "$host: missed cmd(s): %s
    ", join(',', keys(%commands))) if ($debug);
    if (!$clean_run || !$found_end) {
    print STDOUT "$host: End of run not found
    print STDERR "$host: End of run not found
    " if ($debug);
    system("/usr/bin/tail -1 $host.new");
    unlink "$host.new" if (! $debug);
    ##### END OF FILE #####
    ****** Step 2 ******
    Now, edit your rancid-fe file to add the following 'aruba' line (leaving all the other lines in there):
    %vendortable = (
    'aruba' => 'arubarancid',
    ****** Step 3 ******
    Edit your hidden .cloginrc file (maybe in your /home/rancid directory) to set the autoenable
    Add the following lines - braces are literal, while parenthesis are just for your reading pleasure:
    add autoenable (hostname of 7005) 0
    add user (hostname of 7005) (username)
    add password (hostname of 7005) {password-here}
    NOTE: In the file you created (arubarancid) from the past above, the following will cause RANCID to remove the LDAP key (relax, it's already in there):
  • 8.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted May 13, 2015 04:11 PM
    Thanks to fsweetser for the seed arubarancid file.
  • 9.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted May 16, 2016 09:56 PM
    Thanks for files. I was able to use files attached, but I noticed they are giving
    "couldn't compile regular expression pattern: parentheses () not balanced" error on some Aruba devices.
    It turned out that length of the hostname could be the issue.
    Hostnames less or equal 9 symbols are good and work perfectly.
  • 10.  RE: Does anyone have an example arubarancid or arubalogin script for RANCID that's working?
    Posted Aug 04, 2017 01:38 PM
    UPDATE for 6.5.x.x
    Also add (to the file above):
    # filter out LDAP admin-passwd keys (post 6.5.x.x code version)
       if (/^(.* ap-console-password).*/) {
