Contributor I
Does anyone use AirPcap to capture packets on the WIFI side using Wireshark?
I can see the management frames and radio.tap info but I can't see DHCp request packet etc. like you would on a wired trace. Is there something I need to setup in wireshark to do this?
Re: Does anyone use AirPcap to capture packets on the WIFI side using Wireshark?
You would need to do a capture at the controller after decryption to see this.
Tim Cappalli | Aruba Security
Start here
http://community.arubanetworks.com/t5/forums/searchpage/tab/tkb?location=community%3Aaruba&q=packet+capture
There are a few articles that will help you out here.
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
Super Contributor II
If the client is connecting used a PSK then you can enter the key and SSID into wireshark. If you can then capture the initial exchange of the client connecting to the wireless you will be able to see the decrypted traffic.
