Does aruba has zero configuration APs..
 can we power on AP and let it configure itself?
Re: Does aruba has zero configuration APs..
Yes. It is called Aruba Activate.
Please have a look at: http://www.arubanetworks.com/pdf/products/FS_Activate.pdf
HTH,
-Thomas
Aruba
The APs that support this are Instant APs...no Campus APs already existing can support this activate method.  In terms of Instant, you can order them from the factory and convert them to Campus APs and note that some RAPs are sent out now as Instant APs (RAP3 and 155).
I guess a bit more info is needed to understand what you actually need and want
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
