Frequent Contributor I
Does configured Antenna Gain affect the Powerlevel?
on provisioning Page it is possible to set the Antenna Gain for the External Antennas. Does this Gain affect  the configured Power Output on the RF Profile? Or is it only informational and its necessary to Reduce the EIRP Power manual if an external Antenna is connected.
Best Regards
Re: Does configured Antenna Gain affect the Powerlevel?
mtraettner wrote:
Best Regards
The latter.
Ok so i have to reduce the Powerlewel manul....
How is it with the internal Antennas? Is that Gain considered by the controller or must i reduce the Powerlevel also manual...
Thank you and best Regards
No. You so not have to reduce it manually. It is done automatically.
