Dual ISP on 650 controller ?
Hello,  Is it possible to setup a guest network that routes traffic to a seperate gateway provided by another ISP.  So we would have private wireless network ( 172.16.1.X) using a metroE trunk to home office AND a Guest network ( 192.168.1.X ) using a business internet solution straight out to Internet.
Re: Dual ISP on 650 controller ?
Hi there,
I think the scenario you describe is pretty well covered in the validate reference design guide on the public website.  Here's the link.
www.arubanetworks.com/pdf/technology/AOS_GuestAcccess-AppNote.pdf
Give it a read and post back with questions if this doesn't clear things up.
You might be looking for this:  http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Guest-VLAN-to-separate-DSL/m-p/26858/highlight/true#M2023
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
