Duplicate AP with controller IP address
I am facing a strange behaviour on my WiFi controllers :
  • 2 x Aruba WiFi Controller 7240XM
    • Version 6.4.4.17 (same for AP)
    • Controller 1, @IP = 192.168.10.11
    • Controller 2, @IP = 192.168.10.10
    • HA Mode Dual/Dual, controller 1 = LMS IP and Master VRRP
    • AP concerned : AP125
The same Access Point appears twice in the controller with the "show ha ap table" command, once normally and another with the controller's IP address, and the SL status .
  • This behaviour appears for a different AP for each controller.
Apparently, these AP do not use two licences (only 1), and they are not seen twice with the "show ap active" and "show ap database" commands.
  • On the controller 192.168.10.11 (show ha ap table) :
 AP-PP89   10.10.64.1   00:24:6c:c3:c4:a3  LU
AP-PP89        192.168.10.10  00:24:6c:c3:c4:a3  SL
  • On the controller 192.168.10.10 (show ha ap table) :
 AP-CH306  192.168.10.11  00:24:6c:c5:4f:2b  SL
AP-CH306       10.10.64.41   00:24:6c:c5:4f:2b  SLU       H
What do you thik of that ? I did not find anything related on the release notes.
Thanks for your help.
Re: Duplicate AP with controller IP address
Could be a cosmetic issue. Please open a TAC case
