I was discussing WMM with some folks and I realized that I am missing something here. When I look at the defaults for a new SSID in a VAP profile, I noticed that there are no default profiles set for either of EDCA sections. Is this because the High-Throughput SSID setting is applied and EDCA air-time queuing is being applied automatically (since 802.11e is built into the HT standard)? Would these only need to be set to something if I planned to change the values (which I don't plan on doing). Just want to make sure that voice is getting its appropriate share of air time with these not set. Inquiring minds would love to know!
