Frequent Contributor II
Eduroam issues AP205
Hi all, anyone experienced the following.
Large campus network, running 6.4 code.
Intermittent poor internet access only on 1 SSID (eduroam) and seems to be only on 205 series AP's. All other SSID's connect without issue.
Very odd...
ACMA/ACMP
Re: Eduroam issues AP205
Is the SSID configuration the same as your other networks (with the exception of the ESSID)? Things like data rates, basic rates, etc.
What encryption is in use?
Tim Cappalli | Aruba Security
Hi Tim, I believe this is 802.1x, other SSID's are the same I believe. Has worked for years it is a recent issue, seems to be with 2xx series AP's only.
ACMA/ACMP
Occasional Contributor I
Hi All,
This issue from my testing is only seen on AP205's.
Make the following change to “AP system profile” of all the AP-groups and change the “SAP MTU” size to ‘1500’.
Seems by default no value is set. Making this change had an immediate, positive effect.
Stunshot, please open a TAC case.  This could be a bug or a configuration issue, but it is very hard to tell from the limited information that you provided.  TAC should be able to rule out a few things and ask you about others...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
