Enable Activate Provision on Switch 2530-8G model J9774A
Hello good afternoon to the entire aruba community, I have a problem to activate or that the activation key is visible on a 2530 switch. As an attachment I leave you the capture of what it shows me when you see the activation key
Re: Enable Activate Provision on Switch 2530-8G model J9774A
Please check the serial number and/or manufacturing date of your 2530 switch. If the manufacture date is before July 2017 (the Serial Number is less than CN77xxxxxxxx) , the switch need to be added manually.
For the procedure, please check the Release Notes for the 2530 firmware. Under Important Information, you will find the procedure.
Switches produced after July 2017 should work out of the box.
