Contributor I
Enable Session Timeout on each SSID - AOS 8.2
How can I setup session timeout on SSID?
I mean that after this time, client will be disconnected.
I want to setup on 2 SSID, one with CPPM authentication server and another is open using captive portal
Mobility Controller 8.2.0.1 with Mobility Master
Please support me!
Many thanks
Contributor I
Re: Enable Session Timeout on each SSID - AOS 8.2
I added Re-auth interval in role but It doesn't work :(
Can anyone help me?
