Enable http for webgui?
Our webgui cert got revocked due to the heartbeat vunerability so we can't webgui into any of our controllers on port 4434. The easiest fix would be to enable the webgui on port 80; go in and change the certs and re-enable 4434, but I am not sure how to enable webgui on port 80 from the CLI.
Any help here would be apprecaited?
Aruba
Re: Enable http for webgui?
Can you just configure your browser to ignore revocation status (temporarily) to get into the controller?
AMFX | ACCX | ACDX | ACMX
Yeah that worked.
