Enabling routing in OmniAccess 4306G
Hi Guys,
How to enable routing in OmniAccess 4306G?
Is it via interface vlan only or global as well? Thanks
Aruba
Re: Enabling routing in OmniAccess 4306G
By default, any VLAN you create intervlan routing is enabled.  show interface vlan <id> should give the  status about if Routing is enabeld on that VLAN.
Inter VLAN routing is not going to work until explicitly you provide "no routing" from the VLAN interface which can be viewed by "show running-config"
Thx,
Sriram
Hi Sriram,
I disable ip routing on all vlan interface but inter vlan routing still not working.
Anything I still havent done? Thanks
Aruba
You need to enable ip routing for Inter VLAN routing to work.
Configure terminal
Interface vlan <id>
ip routing
