- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Energy - efficient features on Aruba Switches
05-05-2013 08:02 PM - edited 05-05-2013 08:02 PM
Hello i was wondering if you Aruba guys got some kind of study with numbers of money saving with this kind of feature in which you can shut down APs during specific times.
Like how much energy an AP consumes and how much energy and money it will save you turning these off
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
Re: Energy - efficient features on Aruba Switches
05-06-2013 06:49 AM
Carlos,
We have not done an official study on this but it is a great idea. We do publish the AP power power consumption values (on their respective datasheets) and while this is typically the maximum needed when serving clients, I typically see our APs at least draw 5 watts (if not more) when idle. If a customer is using X number of APs, you could tell them that when the WiFi is not needed, they would save X*5-watts if they used time of day PoE profiles. Additionally, you could also use time of day PoE profiles for other PoE devices like IP phones in non-critical areas.
You can always verify the PoE load on a Mobility Access Switch using "show poe controller" for the aggregate PoE consumption or "show poe interface brief" for a port by port display of PoE consumption.
Best regards,
Madani
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-06-2013 08:21 AM
Hello
Thanks for the reply
I was looking this because i would like to show the client something like this
Like in a year you could be saving x ammount of money in power if you use ArubaSwithes instead cisco switches for example as you can turn off the APs automnatically and turn them on again for example turn of at 10pm and turn them on again at 6am.
If i can tell them with Money numbers then they would understand... if i just tell them they would save energy they would just not consider this as they would think well i dont think its a lot of money so i dont care.
You get my point?
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-06-2013 09:22 AM
Carlos,
Yes, understand the need. We can work on a document covering this.
Best regards,
Madani
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-06-2013 09:24 AM
Thank you this would be really helpful!
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-06-2013 09:25 AM
Please also if you can tell me when a document about this is ready if you could reply this topic of send me a private message as i would like to use it as soon as i can :)
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-06-2013 09:29 AM
Sure.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-15-2013 06:23 PM
Hello Madjali
those 12.5W is 12.5W per hour right?
The other thing that would be nice to have is
How much Energy i mean kWh would consume a switch with all 48 ports using POE and when its not using POE
and well the value of APS how much they consume in kWh
I guess if we get the kWh value we can all do our matematics and get how much savings you are getting.
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-16-2013 10:10 AM
Carlos,
I'm not sure I understand what you are referring to with respect to 12.5W.
Best regards,
Madani
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
05-16-2013 10:24 AM - edited 05-16-2013 10:25 AM
Hello
What i want to know is how much kWh comsume an AP 105 for example
Also how much kWh consume a Aruba switch with POE on( imean all the ports using POE with aps connected to it using it)
And how much kWh comsumes a aruba switch with the POE off
Cheers
Carlos
Alternetworks Corp
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Alert a Moderator
