Occasional Contributor I
Error authentication 802.1x with devices android
I contact you for an issue about the authentication 802.1x with devices android. We use Clearpass behind the controler with EAP-TLS method. The certificate chain is composed of 3 elements (1 CA Root and 2 intermediate certificate). With IOS devices, the connection work perfectly. But with devices android, I get an error when authenticating. I supose that devices android does not support the certificate chain with 2 intermediate because with one intermediate, it work.
Have you ever had this problem ? How Can I debug on controler and Clearpass ?
Thank you.
Re: Error authentication 802.1x with devices android
Are you using Onboard to put certificate on the Android device?
Thank you for your quick reply.
No, I don't use "Onboard" for put the certificate on the device. I installed manualy the certificate on the device (for the test).
We use an other mdm for enrol the devices IOS.
Is it possible to debug this ?
I already used "user-debug" client, auth-tracebuf ...
Trusted Contributor I
more an AAA section question.
if you already determined it worked with one intermediate and not with two i would focus on looking into anroid forums to see if this is a known issue.
you are sure every intermediate is trusted on the clearpass side? if you raise the logging levels you might be able to see something in the access tracker logs.
if you have a support contract be sure to open a TAC case, if you have it working with one interemediate they should be able to look more closely in the two intermediate issue and perhaps provide an answer. be sure to report back with an answer please.
If I can help someone, I found the solution.
In fact, when configuring the android device it's very important to put the username in field "Identity" if not the radius request is stopped because the username is not send. I found that when I used "show auth-tracebuf".
Android can not retrieve the CN in the certificate like an IOS.
Best regards,
