Error message help
I dont have much experience with Aruba yet, can anyone help me shed some light to what this error message is acctually saying and what might be causing this to happen? I have seen some of this problems with RAP5's involved. This is a error log from my primary master where the RAP5's are associated
An internal system error has occurred at file sapd_redun.c function sapd_proc_redun_msg line 4336 error Error: Received RC_OPCODE_ERROR lms x.x.x.x tunnel RC_ERROR_IKEP1.
Thanks in advance
Re: Error message help
Please open a support case.  The context in which that error occurs determines what it means.
Colin Joseph
Aruba Customer Engineering
