Error when Converting AP 105 to CAP
  • 1.  Error when Converting AP 105 to CAP
    Posted Jan 23, 2015 02:55 PM
      We have an Aruba Mobility Controller with 4 WAPs that is working great. We would like to put some more WAPs in our campus, and we have trunked the Mobility Controller to an Aruba s1500 switch. We set up a port on the switchto access the wireless vlan, and when we plug the AP 105 in, connect to 'instant' and convert to a Campus AP we are getting an error that says 'Retrieve Image Failed'  band the following log. We are running Aruba OS 6.3.1.6
    Target : 24:de:c6:c4:88:70
    show vpn status
    profile name:default
    current using tunnel                            :unselected tunnel
    ipsec is preempt status                         :disable
    ipsec is fast failover status                   :disable
    ipsec hold on period                            :600
    ipsec tunnel monitor frequency (seconds/packet) :5
    ipsec tunnel monitor timeout by lost packet cnt :2
    ipsec     primary tunnel crypto type            :Cert
    ipsec     primary tunnel peer address           :N/A
    ipsec     primary tunnel peer tunnel ip         :N/A
    ipsec     primary tunnel ap tunnel ip           :N/A
    ipsec     primary tunnel current sm status      :Init
    ipsec     primary tunnel tunnel status          :Down
    ipsec     primary tunnel tunnel retry times     :0
    ipsec     primary tunnel tunnel uptime          :0
    ipsec      backup tunnel crypto type            :Cert
    ipsec      backup tunnel peer address           :N/A
    ipsec      backup tunnel peer tunnel ip         :N/A
    ipsec      backup tunnel ap tunnel ip           :N/A
    ipsec      backup tunnel current sm status      :Init
    ipsec      backup tunnel tunnel status          :Down
    ipsec      backup tunnel tunnel retry times     :0
    ipsec      backup tunnel tunnel uptime          :0
    end of show vpn status
    show upgrade info
    Image Upgrade Progress
    Mac                IP Address     AP Class  Status       Image Info                      Error Detail
    24:de:c6:c4:88:70  169.254.86.17  Orion     downloading  ac-ftp://10.10.10.2/mips32.ari  Retrieve image fail
    Auto reboot           :enable
    Use external URL      :enable
    end of show upgrade info
    show log upgrade
    ----------Download log start----------
    Executing '/aruba/bin/download_image_swarm ac-ftp://10.10.10.2/mips32.ari X-Ap-Info:BT0571111,24:de:c6:c4:88:70,AP-105'
    fetching ('/usr/sbin/wget -T 120 -t 3 --header=X-Ap-Info:BT0571111,24:de:c6:c4:88:70,AP-105 ftp://sap:x@10.10.10.2/mips32.ari')
    Error: failed to retrieve image
    cleaning up
    done
    ----------Download log end------------
    Download status: Retrieve image fail
    ----------Upgrade log start----------
    upgrade log not available
    ----------Upgrade log end------------
    Upgrade status: upgrade status not available
    end of show log upgrade
    show log rapper
    Rapper info not available
    end of show log rapper
    I'm guessing it's something with the port we set up on the switch. If I plug a laptop into that port I can't ping the switch, the controller or anything. Should it be set up as a trunk port perhaps? Or with a different native vlan? I appreciate the help!
  • 2.  RE: Error when Converting AP 105 to CAP
    Posted Jan 24, 2015 05:19 AM
    it shouldn't matter whether its a trunk port or access port, as long as the vlans are right and you have connectivity to the IP of the controller this should work. Get ping working first and then deal with the AP. Double check that all the ports are all set to trusted as well.
    looks like you may not have working DHCP on the AP port either, the AP appears to have 169.254.x.x address, so check into that first.
    If there is meant to be DHCP elsewhere, or it's still stuck after putting local DHCP then take another look at the vlan setup, don't forget that the 1500 MAS doesnt automatically trunk all vlans, you have to add them each.
    check your vlan and port membership on the controller:
    show vlan status
    show port status
    show trunk
    and check it on the 1500 side too:
    show interface status
    show port status
    show vlan detail
    show trunk
    also make sure that PVST hasn't blocked the vlan for any reason:
    show spanning-tree vlan <X>
    regards
    -jeff
