Frequent Contributor I
Error - xSec allowed VLANS are required for xSec Point-to-Point Configuration
I'm getting the error mentione in the subject when trying to apply any port configuration in the Web UI of a 7005 controller running 6.4.2.10.
This is a controller right out of the box.  I've licensed it and put some IPs on it.  I was able to get LACP configuration to stick as well.  I started on an earlier version and got the error, so I updated to the latest and greatest and still get the same thing.
I don't have an xSec license and the xSec module is disabled, so I don't understand why I'm getting this message.
Please advise.
Thanks.
*I guess it's not an error, because configuration seems to be sticking, but it's annoying since I don't have xSec enabled anywhere.  Should I just ignore it?
Re: Error - xSec allowed VLANS are required for xSec Point-to-Point Configuration
Open a TAC case to make sure, but you should be able to ignore it. xSec isn't even supported on the 7000 controllers.
Jerrod Howard
Sr. Techical Marketing Engineer
Thanks.  I will put in a request with TAC to let me know if this is something I should be concerned about.
TAC is still working on it in the lab per their last reply to me.
