Occasional Contributor I
Ethernet setting on IAP 205
My first post here & my first work with Aruba wireless :)
Is there any way to force the speed on an aruba 205 access point's ethernet interface to 100/full. A cisco switch that it connects to is showing lot of errors.
The switch side was already tried changing to auto/hard coded.
Thanks in advance.
Ethernet Duplex/Speed Settings
Autoneg Speed (Mbps) Duplex Iface
on 100 Full bond0
ArubaOS (MODEL: 205), Version 6.4.3.1-4.2.0.0
Re: Ethernet setting on IAP 205
Hi
I understand that you have mobility controler. check this profile:
Configuration --> AP Group --> <AP-Group of the desired AP> -> AP -> Ethernet interface 0 port configuration --> Ethernet interface link profile
Regards
Piotr Filip
AMFX#41/ACMX#536/ACDX#878/ACCX#818/CWNA
Give Kudos: found something helpful, important, or cool? Click Kudos Star in a post.
Problem Solved? Click "Accepted Solution" in a post.
I think this is more of an IAP acting as the controller.
Please let me know. Thanks.
Frequent Contributor I
Goto "MORE > WIRED"
Select ETH0 profile and edit
Set Speed
** it will applied to ALL Access Point !!
-Yopianus Linga-
Thanks, but our IAP does not show that option under wired.
It just has fields till admin status.
any other options that i can try please?
some screenshot would be helpful.
-Yopianus Linga-
Make sure you click SHOW ADVANCED setting, or you can try using CLI
IAP-Set Port
-Yopianus Linga-
Hi guys, I searched it in the user guide and here but couldn't find something that addresses the solution. Is there a document that describes how to use the second ethernet port on Ap-225 as an access port for the clients. and for the printer queries go the
Nipson printers  customer service and get the help.
Thanks much. i got it finally.
Just another query , an IAP-275 is currently acting as the IAP controller role. However, there was another IAP acting as controller earlier, but it seems to be flapping on/off. Is there any way to look in the GUI of IAP to see the flaps & its reason to understand the role changes.
I think you should check on the switch logs for that. The main reason IAP changes master/role ussualy because the previous master is down.
Try changing the cable or port of the troubled IAP.
-Yopianus Linga-
