Occasional Contributor I
Evaluation License Issue
Can someone help me how to check how many times the evaluation license is added in the device? i have been facing issue with one of customer that license flag shows Nothing after a day or two.. i did twice write erase all and applied the license and configured the device. This seems to occuring continusly in 7005 controller, will the license work if i erase all and configure again or any other solution to stop this write erase all thing till i get a permanent license in a week. in the installed date in braces it shows (1) does it mean first time?.
If i write erase all and re-configure the device will my license work as i did already 3 times..?
i have attached the screenshot for reference
Re: Evaluation License Issue
(1) means it was used once.
If it shows nothing after a couple days, that is probably a bug and a TAC case should be opened.
If you write erase all, you should be able to use it 3 times again.
Thanks Joseph...
When i write erase all and re-configure the device everythig  works pretty fine and i can see that License "E-Enabled" in flag after the reboot... one observaton here is my primary got rebooted suddenly.. where all the AP's are shifted to secondary and few AP's work in secondary few AP's are showing up in "Flag - IL" ... will raise a TAC case too to check for any know issue in this model as i faced this issue in more than 5 devices recently...
hi ,
  • i think that the best is to buy that your customer buy permanent licence.
  • if not you can use temporary licence for 3 month , after that you can backup your configuration and you write erase all ,and you use your backup.
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
