Super Contributor II
Explanation Required
I shall be thank full if any one can explain the "AP Classification" and " Event" tabs
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
Re: Explanation Required
In the ArubaOS 6.1 user guide, there is a Chapter Called "Wireless Intrusion Prevention" which explains this.  http://www.arubanetworks.com/techdocs/ArubaOS_61/ArubaOS_61_UG/New_WIP.php#XREF_57637_Monitoring
Thank you  cjoseph
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
