bs1
Exporting BSSIDs and AP Names
Hi, long time listener, first time caller.
Does anyone know of a way to export all the BSSIDs and their associated AP Names either from the Master Controller or Airwave?
I want to try and import the csv file into WiFi Explorer so the Annotations will display the AP names.
Any help is appreciated.
Community Administrator
Re: Exporting BSSIDs and AP Names
Hi-
Give this a shot in CLI, it may be what your looking for.
(7024) #show ap bss-table
CWNA, ACMP, Security +
Second on what Jamie suggested, Another method is from Airwave - if you navigate to the monitored controller, you can run the above command from the CLI drop-down, export the text file cleaning, process it in excel (ap-name name-ssid-band)-checking for duplicates. I used to do this in the past for Wifi-Analyzer.
#AirheadsMobile
