Exporting data from an Aruba 6000 Controller
Is there way to export the data from an Aruba 6000 Controller?  I wanted to export all of our AP's into an excel spreadsheet and then run a script to update all of the names from their MAC address to our common name format that is listed in another spreadsheet.
If there is a way to do this, I could be happy to share this process once it is complete.   Thanks!
Re: Exporting data from an Aruba 6000 Controller
Just import the output of "show ap database long" into a text file and import it into excel...
Colin Joseph
Aruba Customer Engineering
