Extending existing wireless network to substations
I have an existing indoor wireless network of iap105's and iap205's at our main office that's working great.  We have 10 substations connected via fiber and I would like to expand our current wifi out to the substations.
Each substation is on it's own ip network with static addressing only.  I planned to deploy an iap275 at each substation to begin with.  I'd like to use the iap275 to also provide DHCP at each substation.  What would be the recommended solution?  Should I set each of them up as a seperate virtual controller?  If yes, how would I centrally manage them?
Thanks!
