External battery or external poe supply with battery site survey
What do you guys use for site survey?
I was trying to contact tekkeon as  i read some have used that but they dont reply so i guess they out of bussiness or something...
Anyways  i would like to know if you guys use something else and also were can i buy it online
I saw a user said http://www.veracityglobal.com/products/ip-camera-installation-tools/pointsource-wireless.aspx
Looks interesting, but a little expensive...
But anyone got anything else?
Cheers
Carlos
Alternetworks Corp
Re: External battery or external poe supply with battery site survey
Hey, we've always used the below in the past! A little on the heavy side but usually provide a good fulls day worth of power and the internal batteries are extremely easy to replace should their life cycle count start going up!
http://www.terra-wave.com/shop/80211n-mimo-site-survey-battery-pack-p-1535.html
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
