Frequent Contributor II
Extract RF Plan from switch following "upgrade" to 6.3
As above really, seems a real step back to loose the RF plan feature. Now when a client phones up about poor reception we can't tell which access is nearest to that room.
I do have flash backups pre upgrade, can they be extracted them these? Thanks.
Re: Extract RF Plan from switch following "upgrade" to 6.3
Only if you restore it to a controller, pre-6.3 can you get the RF plan off, unfortunately.
 ok, that's progress (
