Regular Contributor I
Fast Failover 6.3
I've configured HA and FastFailover and it works great. However, does anyone know what the preemption hold-down timer is set to or where it can be configured?
Josh
___________
ACMP, ACCP
Aruba
Re: Fast Failover 6.3
The timer is in the ap system profile. Once the connection with the active controller comes back, the ap will wait for x seconds as defined here until it flips back.
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Do you know the exact setting in the AP profile? The only timer I see if the LMS Hold-down Period, which I wouldn't think would apply to 6.3 HA since the first thing you do is remove the backup LMS IP.
Josh
___________
ACMP, ACCP
Aruba
No. That timer does apply
Sent from my iPhone
Seth R. Fiermonti
Email: seth@hpe.com
