Trusted Contributor I
Fast Failover - Migrating APs Between Controllers
With fast failover configured, and preemption disabled, is there a command to do the following:
  • Move APs to standby controller
  • Move APs from standby to active
If not, how do you typically fail APs between controllers in an HA group?  I'm interested in the least disruptive option possible.
If a reply adequately addresses your issue, please click on the "Accept as Solution" and "Give Kudos" button so this information can benefit other users.
Re: Fast Failover - Migrating APs Between Controllers
Try using the ap-move command.
ap-move all/<ap-group>/<ap-name>
Tim Cappalli | Aruba Security
