cau
Fast failover using bridge mode, is possible??
 Is it possible to use fast failover with SSID in bridge mode?
Thanks in advance.
Re: Fast failover using bridge mode, is possible??
According to the release notes, this is supported since ArubaOS 6.4.1.0:
2018-01-19 10_05_57-ArubaOS 6.4.1 Release Notes.pdf - Adobe Acrobat Reader DC.png
Bridge mode, in general, is deprecated, as you are probably aware of.
