rom
Ferry Boat 15km coast to coast
[ Edited ]
Hi to the community,
I am interesting in providing a solution with MIMO outdoor antennas and .11n in three different points.
Point A and point B are the coast stations and the point C is the Ferry Boat which goes from Point A to Point B and back again.
The distance between point A and B is not more than 15km. Ferry must have a constant connection with either one of the coast stations (WDS).
My question is what kind of antennas I have to install to every point? Take into consideration that the ferry boat requires wide beamwidths both in azimuth and elevation. Thank you in advance for your replies!
Moderator
Re: Ferry Boat 15km coast to coast
The antenna used on the Ferry boat has to be low gain Omni since the boat will wallow in the water.
As a result, the antenna used on the coast has to be very high gain to cover the distance, such as 23dBi and above. However, Aruba products are not certified to use such high gain antennas. The maximum we've certified is 14dBi, the ANT-2x2-5614.
Best,
Xu
rom
[ Edited ]
ic,
I had the impression that the distance is limited by the weekiest antenna of a link (in this case by the low gain omni) regardless the gain of the antennas of the coast points.
Is there any way to use multiple sector antennas to replace a single omni? (sectorized omni)
Moderator
Since the boat will move on the water, you need both good horizontal and vertical coverage. Most high gain antenna will only give you one, either horizontal or vertical, but not both. That's why low gain antenna is preferred.
Best,
Xu
