Filtering Cisco PVST+ multicast using MAC/ethertype acl?
[ Edited ]
Just wanted to make sure that this is the best way to accomplish this task. Also, is there an implicit deny all at the end of a MAC acl?
Re: Filtering Cisco PVST+ multicast using MAC acl?
Mmm, reading the manual says it only filters the source. Any way to filter by destination?
I'm thinking it would be better to filter by ethertype instead. Would 7005 Ungermann-Bass Bridge Spanning Tree be the correct ethertype to filter on?
