Frequent Contributor I
Firewall openings for Mobility Master
Hi
I'm planning a Mobility Master setup there the MM will be in a separate network and managed devices placed on multiple subnets protected by firewalls.
What port openings must be done for the Mobility Master?
I have tried to find the information in user guides, startup guides etc, but so far I haven't found any consolidated information about the ports needed for a Mobility Master to work.
Are there any document describing port needs for AOS 8.x? For 6.x I have found several.
Regards
Jonas Hammarbäck
Re: Firewall openings for Mobility Master
Please see here:  http://www.arubanetworks.com/techdocs/ArubaOS_81_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Firewall_Port_Info/Communication_Between__D.htm
Is it also the same ports between the Mobility Master and the managed device as between any managed devices?
Regards
Jonas
Managed device = MD = controller managed by a Mobility Master. The link above describes those ports. The short answer is yes.
Thank you for the clarification!
Regards
Jonas
