Regular Contributor I
Firmware upgrade 651 Controller
Hello community,
I´ve a problem.
I´ve a second controller and want them as a backup for my master.
I put the controller out of the box and the firmware 3.4.2.4 is running.
I ´ve dowload the 6.2.1.4 firmware and boot it. There are no warnings or something, but the contrillers gui wont work right.
Have anybody an idea?
It looks like a mix between 3.x.x.x firmware and 6.2.1.4.
Re: Firmware upgrade 651 Controller
Can you try a different browser or clear your browser cache? This is common when upgrading to drastically newer controller code.
Tim Cappalli | Aruba Security
