Flash Memory Issue
Dear all,
my 7030 controller  do not save configuration , and every time he boot with the wizard page , in the loading process i found that it got a flash issue (less than 1 mb)7030-2.png
how can i do to cleanup the flash from the cpboot
Regards
Raouf CHAHBOUNE
ICT Network & Security Engineer
CCNP R/S | CCNA Security | ACMP|ACCP|ACDX
[If my post is helpful please give kudos, or mark as solved if it answers your post.]
Re: Flash Memory Issue
Ignore, this didn't see the part about cpboot.
ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
