Frequent Contributor I
Flexradio APs
We've got some AP-203H units with the flexradio wotnot. Does anybody know how to configure these as 2x2 single band APs within a controller?
I've had a quick look around and nothing has jumped out at me, but I'm very happy to be pointed towards documentation I've missed.
I've tried disabling a radio, and I end up with a single stream AP with one disabled radio, so there's something else that needs to happen.
Re: Flexradio APs
Are you running them as Instant, AOS 6.5, or AOS 8.2?
Jerrod Howard
Re: Flexradio APs
AOS on version at the moment.
Re: Flexradio APs
The AOS user guide has a section called "Enabling Flexible Radio".
