Contributor II
Force EIRP and Channel for 802.11a .
Hi everyone,
For a site survey, we want to be able to force a Channel and a signal force.
It work perfectly for me with the 802.11g in those section :
RF Management
   802.11g radio profile
      Transmit EIRP : 15 (Exemple)
      Channel : 10 (Exemple)
RF Management
      Adaptive Radio Management (ARM) Profile
         Assignement : Disable
Then 1-2 minutes after, in the dash board, I can see that the Channel et EIRP are force.
But when I do the same for 802.11a (in the 802.11a radio profile of course), it doesn't work. The value that I want is :
EIRP : 15
Channel :140
Anyone have an idea on that ?
Thanks.
Re: Force EIRP and Channel for 802.11a .
Is channel 140 allowed on your regulatory domain for that access point?
show ap allowed-channels ap-name <name of ap>
Contributor II
Thanks it was the problem...
Don't know why I was stick on that channel. I could try to see if another one was ok..
I was just wondering how the transmit EIRP in the radio profile and Min/Max Tx EIRP settings relate?  For example - Does the Transmit EIRP setting in the radio profile takes precedence over the Min/Max Tx EIRP setting in the ARM profile?  When would you use the setting in the radio profile?
Thanks in advance.
-Luis
The TX EIRP in the radio profile is used when:
- The Access point is fresh out the box and just contacted the controller (this will be the initial power)
- The ARM setting is to None.
Thanks for the explanation!
